SWAPPED for a lower miles 4.8l
Somebody, please help me.I have a 99 Chevy Silverado.L.S 4.8L No, the motor hydro locked on me.About two months ago I bought the same owner just a year.Newer four point eight l s out of a silverado A hundred and thirty thousand miles I got the motor put in then.I then I realized my starters bad So I finally get a starter I'm getting fuel up front from the little service. Valve on antique so I know, I have you. I'm almost positive. I'm getting sparked, cause I'm gonna swap out 2 different racks of coils and plugs. I've reset the f****** computer.Should I please tell me why this mother****er's not starting for I take it to the scrapyard
[QUOTE=frank1;502926]Wa ? the motor in my 99 silverado it locked up SO i got a motor from a salvage yard. Same size Motor 4.8 LS BUT it came out a 2002 silverado and I Am Getting No spark Would the 02 motor work with my 99 Pcm?
I have 2 crank sensors an I tried both Ao unless i just so happen 2 Havw 2 Bad Sensor do you know if there A way to relearn pcm
You've already swapped the coils and plugs, which is a smart move. To check if you're getting a spark, take out a spark plug, connect it to the spark plug wire or coil, then touch the plug's metal part to the engine to ground it. Have someone start the engine, and see if you get a spark.
frank1 (May 2nd, 2024)
