Crank / Woodruff Keys - Replace or Leave?
Hello Members - I'm replacing a timing chain and sprocket on a '76 SBC, and about to remove the crank sprocket and have come across an issue that isn't mentioned in my rebuild guide. My query is about the crankshaft keys (or woodruff keys). I'm not sure if you are supposed to remove / replace them each time you replace the crank sprocket, or can they stay in-situ, etc? What its best practice? They aren't expensive and I have found online how to install them, but I can't seem to find when they need removal or installation. I've had to stop progress in fear I'll damage something. Thanks in advance for any assistance.
If the key is in good condition - no chips, rounded corners, or other obvious wear - there’s no reason to replace it.
If you’re not sure, fit the new crank sprocket on the key and see how much it will move/rotate. It should be a snug fit - if not, replace the key.
So, I'm swapping out the timing chain and sprocket on my '76 SBC, and I hit a snag with the crank sprocket removal. I'm wondering if I need to mess with those crankshaft keys or if they can just chill where they are. They seem fine, but I'm not sure if they need replacing every time.
As for replacing the key…
Spoiler
mmartin8888
Engine Building & Overhauling
November 9th, 2022 10:01 PM
