Help!!! Accessory power outlet not working!
Old October 23rd, 2007, 4:57 PM
nature_boy_ky's Avatar
Default Help!!! Accessory power outlet not working!
I was using a portable 12 volttire inflator to put air in tire. After about 5-10 minutes tire inlator stopped working. I did not have engine running while powering inflator. The inflator will work in cig lighter. Checked the aux power fuse and it was ok.Arethere any other fuses in connection with the accessory power outlet? Any info would be appreciated. Thanks
Old October 23rd, 2007, 8:02 PM
mudderfan's Avatar
Default RE: Help!!! Accessory power outlet not working!
i had that happen to me. i checked the fuse i thought it was and it was fine. it turned out to be another fuse. that happened to me about 3-4 times while using a power inverter
Old October 23rd, 2007, 8:26 PM
Do you remember what you did to fix it? Thanks
Old October 23rd, 2007, 10:43 PM
mudderfan's Avatar
i just kept double checking fuses, found out which one it was, and put a high amp fuse in there. i dont really know if thats the same problem youre having though. i wish i could be more help. i am sorry.
Old October 24th, 2007, 1:24 AM
engine2's Avatar
It maybe the tire inflator. Some are built to cycle off after 10 minutes so it can cool down for 10 minutes. Just a thought
Old October 24th, 2007, 8:02 AM
mudderfan's Avatar
good idea...
Old October 24th, 2007, 10:25 AM
MalibuMaxxSS's Avatar
ORIGINAL: engine2
Kinda what i was thinking, my GF POS tire thng overheats about every 5 minutes, and you have to wait for it.....
Old June 24th, 2008, 10:37 PM
jkgray80's Avatar
Aux power outlet is bad. Buy a new outlet & bezel for about 12 bucks from GM.
Old June 25th, 2008, 9:11 PM
old dog's Avatar
st an idea but check your compressor in another vehicle ,also some of the accessory cig lighter power plug's have fuse's in them !
Old March 14th, 2023, 9:47 PM
Customsneaksnvanz's Avatar
Default Damn
Outlet won't trun on. ...
Quick Reply: Help!!! Accessory power outlet not working!
