2001 Chevy S-10 gas gauge issue
I have a 2001 Chevrolet S-10 crew cab 4x4. I am having issues with the gas gauge. It goes from 1/4 tank to empty in a matter of seconds. Sometimes while I am driving, other times after I turn the truck off and back on. I had the fuel pump replaced last year and again last week. The dealer also replaced the sensor in the tank. None of these repairs have fixed the gauge. I am sick of going to the dealer only to be told there is nothing wrong. Is this a common thing with S-10's? Any suggestions on what it could be and how I can get it fixed? Thanks in advance!
RE: 2001 Chevy S-10 gas gauge issue
I know this may sound funny to most mechanics, but if you take the positive cable off the battery spark it a couple of times and put it back on, it may solve your issue. If it makes your speedometer go to 100, you have a bad gauge cluster. It shouldfix the fuel guage... I can't explain why, it just does it.
I have a similar fuel gauge problem in my 99 S10 Ext Cab. You say "take the positive cable off the battery and spark it".
Can you tell me what you mean by "spark it a couple of times"? Or how you "spark" the positive cable.
Thanks . . .
Thanks . . .
ORIGINAL: EuroGoldLS
Former Moderator
Honorably Retired Member of Staff
It seems to be a common problem, mine has it too. It doesn't bother me though, I know how much mileage I get per tank, so even if it just stopped working it doesn't matter to me. I wouldn't spend all that money having sensors and pumps replaced, just to fix a "cosmetic" problem.
It's interestingto find discussions on this same subject on every GM car/truck forum on the web. Here's a link to a thread on a Corvette forum that seems to have a consensus on correcting the problem.
http://www.c5forum.com/cgi-bin/ultim...ic/1/4666.html
Most of the posts say the use of cheap gas leads to the problem. Top Tier fuelshttp://www.toptierfuels.com/are recommended.
GM has formulated a fuel treatment to correct the problem.
"Use this new additive by GM which has a new ingredient to eliminate the fuel gauge problem (make sure you get the new stuff, which has the "PLUS" on the label):
GM Fuel System Treatment PLUS, Fuel Sending Unit Corrosion and Fuel System Deposits
2006 and Prior All GM Cars and Trucks
GM Fuel System Treatment PLUS, P/N 88861011 (for U.S. ACDelco®, use 88861013) (in Canada, 88861012), is now available. "
http://en.allexperts.com/q/GMC-Repair-813/Fuel-guage-reading-empty.htm#b
jkiff92
March 9th, 2015 9:51 PM
MrEarp
August 23rd, 2012 1:40 PM
allmaneaglesfan
January 11th, 2011 10:19 PM
