Front End Noise
Old November 14th, 2007, 2:25 PM
buzzfin's Avatar
Default Front End Noise
I have a 2002 Tahoe 2WD which has developed a grinding/rubbing noise in the front end (seems like driver side wheel). It is constant, even at low or high speeds. When I turn the wheel even slightly to the right, the noise stops.I originally thought it was just tire noise and that I needed to rotate my tires, but the noise is getting too loud and it also continued even when I pulled the tire off and used the spare. Nothing is rubbing against the tire or suspension. Could it be a wheel bearing?
Old February 16th, 2008, 6:54 PM
rikstr's Avatar
Default RE: Front End Noise
It's the wheel bearing, I'm having the same problem with my 2006 Express cargo van. I'm hearing this is rare, but quite a few people are reporting this problem, so much for sealed wheel bearings. Mine only has 38k miles on it and I don't drive it hard, this is BS.......
Old February 20th, 2008, 10:28 AM
citibar's Avatar
buzzfin, was that your problem with your tahoe , the whinny noise that occures at 10 mph and up, my sound like its comming from the front right wheel, I too rotated my tires and with no luck the noise did not stop, when turn the steering wheel to the right it stops. please let me know before what you did to fix this problem.
thanks citibar6
TASpinney9110
March 15th, 2011 5:54 PM
mandrus
March 12th, 2010 7:45 PM
02blue1
May 30th, 2007 11:45 PM
slimnottygirl
March 7th, 2007 4:40 PM
02TrailBlazer
March 14th, 2006 2:28 AM
Quick Reply: Front End Noise
