Chevrolet Malibu
TRANSMISSION STUCK IN PARK
Old November 16th, 2007, 3:07 PM
txsugarbear's Avatar
Default TRANSMISSION STUCK IN PARK
[]My malibu is in the garage and I can't get itout ofpark. I pumped the brakes..I held in the button on the stick...nothing.....Help!!!!! Someone at the chevy dealer (grrrr) told me it might be the brake switch?...ok...blondefreeze here...WHY would it have anything to do withthe brakes. Thanks in advance!!!
****Combined consecutive posts*****
MAKE THAT P A R K SORRY
***Please use the edit function to add corrections or afterthoughts to your post.***- EuroGoldLS
Old November 16th, 2007, 4:04 PM
Default RE: TRANSMISSION STUCK IN PARK
The reason he told you it has something to do with the brakes is because you have to press the brake to shift from park. When you press the brake about a quarter of the way down, the pedal trips a switch that allows to depress the button and shift from park.
What model Malibu is this and how exactly does the shifter behave? Does it freeze and not move, or can you move the stick into reverse. Knowing this will indicated whether you have a linkage problem or a transmission problem.
Old November 17th, 2007, 7:55 AM
I have a 1997 Malibu
BigblackHo3
April 5th, 2013 8:54 AM
bdm408
September 7th, 2008 6:24 PM
fredski53
July 21st, 2008 11:45 AM
bdawg0958
Sonic (Aveo)
November 18th, 2007 2:07 PM
bdawg0958
November 5th, 2007 3:55 PM
Quick Reply: TRANSMISSION STUCK IN PARK
