Old August 10th, 2015, 7:14 PM
Browse all: Powertrain Guides
Turn OFF Check Engine Light?
Old December 1st, 2007, 6:28 AM
Bolander's Avatar
Default Turn OFF Check Engine Light?
[hr]Besides having the codes cleared with a scan tool, what is the DIY procedure for turning off/resetting the check engine light?
Old December 1st, 2007, 6:30 AM
Bolander's Avatar
Default RE: Turn OFF Check Engine Light?
[hr]Forgot to mention, above is in regards to a 1997 Silverado 2wd 5.0L.
Old January 13th, 2008, 12:41 PM
tedco21's Avatar
It has to be cleared with a scan tool.
Old January 14th, 2008, 6:56 AM
tedinindy's Avatar
You gottafigure outwhat caused the check engineand fix the problem. Depending on the code or codes involved once fixed the light will stay off. A few codes will require a determined number of on/off "cycles" without error before it will go out. You can always erase codes by disconnecting the battery for at least a half hour. That resets the PCM. The check engine light will come right back on and stay on till you fix whatever iscausing it
Old January 12th, 2013, 6:32 PM
cffcjoker's Avatar
I can reset service engine lightby removing the two ecm fuses and turning key on for ten minutes reinstall fuses start truck this is on a 2000 silverado worth a shot
Old February 7th, 2018, 8:14 PM
all depends on where the information is stored. A LOT of new vehicles will not clear with a battery disconnect...keep alive memory. For the ones that do clear...you could also lose the engine and transmission adaptive learn memory. the scan tool may not be the only way but it is the best way.
Old February 14th, 2020, 4:09 AM
M, Calloway's Avatar
Default Clearing the SMS light on my dash 04 C which one is it to removing cute ischium right
Which to of the ECM fuses.. I've an 04 4.8 half ton Silverado ls.?
redrotor
Cobalt
August 29th, 2019 8:38 PM
2001impalaflip
March 22nd, 2013 12:23 PM
psd7.3
December 22nd, 2010 8:23 PM
Engam
November 7th, 2010 10:21 AM
Mr. Vann
November 25th, 2009 7:24 PM
Quick Reply: Turn OFF Check Engine Light?
