Do you rotate your own tires?
Old February 19th, 2008, 12:14 PM
tahoe's Avatar
Default Do you rotate your own tires?
It's about that time to do my first rotation. I was wondering if should take it to the Stealer. I'v read that poeole have problems with the TPMS.
Old February 19th, 2008, 12:19 PM
bimmerborn's Avatar
Default RE: Do you rotate your own tires?
I did rotate myself. I too read about TPMS issues and got me worried. I decided not to reprogram TPMS. How I rotate is put the fronts in back and backs in front. I do not cross wheels so the tires rotate in the same direction as before.
Old February 19th, 2008, 12:39 PM
jsm
jsm's Avatar
I'm going to do myself. Owner's manual tell you what to do about pressure sensors; it doesn't look all that difficult to relearn tire positions. Check it out.
Old February 19th, 2008, 12:51 PM
mary900's Avatar
Rotated and re-programmed TPMS at home.
Followed the instructions in themanual on how to re-program TPMS.....piece of cake.
Old February 19th, 2008, 1:03 PM
kpanza's Avatar
Rotated at home, the TPMS re-program didn't work...next time at the stealership I'll have them do the re-program.
Old February 19th, 2008, 4:46 PM
Did mine myself and reprogrammed TPMS. No problem except those factory 20s weigh a ton.
Most of those I've seen on forums that have had problems reprogramming have had the new rubber sensors.
Old February 19th, 2008, 6:16 PM
tahoe's Avatar
I think I'll just go to the Dealer. They quoted me $25 for all four. I guess that it will save the headach if I'm not able to relearn the TPMS. BTW $25 ain't bad, is it? Has anyone gotten it done for less
Old February 19th, 2008, 6:22 PM
$25 is a little high. I would expect $15-20.
Old February 19th, 2008, 6:56 PM
tahoe's Avatar
I'll see if they can give me their employee pricing. When I bought the hoe I was able to work them for 3 tanks of petro. I guess it won't hurt to try to get a better deal. Its funny they would give me gas slips to go fill up and I'll get nothin but the good ish.
Old February 19th, 2008, 8:18 PM
My dealer rotated and balanced with hidden stick-on weights for $45. With less than a 1,000 mi on it, the clip-on weights had already started to wear thru the clear coat. []
Quick Reply: Do you rotate your own tires?
