DTC code p1665
DTC code p1665
I had my DTC codes read today and had a code that i dont know
it is on a 1998 monte carlo with a 3.1
Transient DTC P1665
Driver 3
Line 5
i have no idea what this means if anyone can help i would be thankful
thanks justin
Transient DTC P1665
Driver 3
Line 5
thanks justin
RE: DTC code p1665
I google search brought this back.
http://chevrolet.justanswer.com/uplo...1665-Debug.pdf
RE: DTC code p1665
The code is for the evap vent solenoid, its probably the vent solenoid itself. You can take the solenoid off and hook some wire to it from a battery and it should click each time you touch the battery if it doesn't then its bad.
RE: DTC code p1665
it's an evap code for your vent valve you can check fuse 42 in your fuse block and 12v on the pink wire at the vent valve but9 chances out 10it's the valve if u dont know where it is it's
Behind the left rear fascia splash shield in the wheel well. good luck!
Help
so i have a 98 monte carlo. its been parked for a while because of the service engine light. i finally got someone to look at it today and actually scan it and it gave me two codes.
first one was P0440 Evaporative emision. and i changes the fuel cap because thats what everybody told me to do. idk if it has worked or not because i just did it.
any help with that one?
the other code was P1665 which the scanner told me it was fuel level output system or EVAP vent control system?
i really dont know what this means. and i need help ASAP. this is my only car and i need it to drive to school and work. does someone have any ideas? please help.
<!-- / message -->
<!-- / message -->
