S-10 & Blazer 1982-2005
Transmission fluid change
Old April 3rd, 2008, 6:05 PM
blazerman's Avatar
Default Transmission fluid change
My blazer has high milage. First I wanted to know how many quarts of transission fluid will it take to change it? Just to know I am going to drop the pan and put on a new filter not try and get it all out of the torque converter. My next question is I have heard horror stories of changing the transmission fluid at high milage because the fluid has all the clutch material in it. Is this a myth or reality, and should I change my fluid at high milage?
Old April 3rd, 2008, 7:10 PM
Default RE: Transmission fluid change
No, its very good for it to get rid of that contaminated fluid. If you are dropping the pan, it should take no more than 6 qts. Make sure the metal ring that comes on the end of the filter comes down with the filter when you change it.
Old April 3rd, 2008, 9:02 PM
blazerman's Avatar
How is the best way to get the fluid to the right level on the dip stick? I usually always go under or over.
Old April 4th, 2008, 3:52 PM
Former Moderator
Honorably Retired Member of Staff
rabbit0102030's Avatar
There is not really an exact science to it.
Old April 5th, 2008, 11:08 PM
blazerman's Avatar
Oh Okay thanks for the information. Do you know if it will hurt it if it is over or under filled by a little? I am going to try my best to get it perfect but incase.
newcster68
April 10th, 2021 5:59 PM
dhuberasu
HHR
February 13th, 2015 1:56 PM
DeHartShadow
March 28th, 2010 10:10 PM
ROAD_DOG
September 26th, 2009 3:53 PM
Big D
March 27th, 2009 1:19 PM
Quick Reply: Transmission fluid change
