Outside air temp sensor
on
Just put a 06 impala mirror in my 07 impala, it has a compass, and outside air temp plus auto diming and onstar. Everything works but outside air temp. Where is the sensor located?
RE: Outside air temp sensor
If the car didn't come stock with that option, you will probably have to add the sensor and maybe a harness. If the harness isn't there, you'll more than likely be inserting pins into the connector at the mirror
on
I'll check it out. No it didn't come with that option but i'll bet they only make one harness for impalas. I figured i'd need to buy sensor.
skategranger
February 18th, 2013 2:38 PM
