Need Help Changing Spark Plugs on a 2005 2500HD with 6.0 Gas Engine
Old May 1st, 2008, 2:37 PM
Lees2500HD's Avatar
Default Need Help Changing Spark Plugs on a 2005 2500HD with 6.0 Gas Engine
I have been having a issue with rough idling. You can actually see the tach jump a little at times. Truck has a little over 44K. miles.
Which way loosens the plugs clockwise or counter clockwise. Are they in there tight from factory?
Thanks Lee Stroud
Old May 1st, 2008, 2:45 PM
northey87's Avatar
Default RE: Need Help Changing Spark Plugs on a 2005 2500HD with 6.0 Gas Engine
I would imagine that the plugs are just like every other spark plug and loosens CCW.
Old May 14th, 2008, 2:53 PM
bennettmcguire's Avatar
I just did my truck.. Same engine.. I'm certian it was CCW.
Old May 14th, 2008, 3:57 PM
jmack91z28's Avatar
Lefty Loosey Righty Tighty...
Put your *** into it, they'll come off
Old May 14th, 2008, 4:21 PM
ZX1100F1's Avatar
I heavy dose of fuel injector cleaner will probably do more to smooth out the idle then a new set of plugs.
And it is CCW to remove each plug of course.
Old May 14th, 2008, 7:45 PM
wellmax's Avatar
you could have a defective plug, but before I changed plugsI would give truck a couple of cans of seafoam, (one per tank) see if that helps.
Also change gas stations, try Shell or other well know brand. some of the gas companies use additives that hurt mileage and performance, but meet EPA stds.
Good luck and let us know what fixed the problem.
Be sure to use proper AC Delco plugs, if you do replace plugs, not some off brand plug, they can cause sensors to go crazy.
Old May 16th, 2008, 6:45 AM
jmack91z28's Avatar
To make it easier next time, put a dab of anti-seeze on the threads of the new spark plugs when you put them in.
And definatly only use Ac Delco. Autolites are for Ford's, they like to run off of crappy parts like that. haha
Old May 24th, 2008, 11:45 AM
therewolf's Avatar
Just did the change on my 04-6.0LQ4 at 57k miles. Do it with engine cold,direction CCW. And dont believe that 100k tripe from Chevy, either, mine were getting ready to melt right off the side of the engine. Be sure to use AC Delco replacements.
Old May 29th, 2008, 9:49 AM
CRHebert's Avatar
Do you need any special tools to change the spark plugs? I have a 2002 2500HD 6.0L.
Old June 29th, 2008, 6:04 PM
jeeves9151's Avatar
I just changed the plugs on my silverado. Clockwise tightens and Counter-Clockwise loosens. My engine was having problems around idle, with the tach jumping around and the engine killing if it was in gear. I went back an tightened all of the plugs and made sure the wires were on tight and the problem was solved. A torque wrench helps witht tightening the plugs but is not necessary, and they are not too expensive(20-50 dollars).
alka
Astro
January 26th, 2020 2:44 PM
2004CMM
July 21st, 2010 6:39 PM
ddls1
June 25th, 2010 6:09 AM
06uplander
Uplander
June 2nd, 2010 7:33 AM
epekarik
July 14th, 2006 12:51 AM
Quick Reply: Need Help Changing Spark Plugs on a 2005 2500HD with 6.0 Gas Engine
Top
© 2024 MH Sub I, LLC dba Internet Brands
Follow Us
