92 chev 350 timing
92 chev 350 timing
I have a 1992 Silverado with 330,000 Kms or 200,000 miles, what degree would you suggest setting the timing at? Advanced or retarded? I don't believe it has been rebuilt and everything is stock. Thanks.
Jonathon Hickman (November 12th, 2019)
RE: 92 chev 350 timing
Thanks for the info, but,where is the spark timing by-pass connector Located at? I've never even heard of one of these. I sure do miss my old 81 Camaro with a carburetor andzero sensors, so much easier to work on.
there should be a 2 wire harness near the distributor. Usually taped to another harness. There is a gray plug in it that should pull out.
With the key off, pull the plug, start the engine, the check engine light should come on, time the engine, turn the key off, replace the connector, and start the engine. Check engine light should be off and it should run good
92 chevy Silverado 1500 4x4 no start
I replaced rotor button distributor cap and spark plugs along with spark plug wires and ignition control module. It will crank but will not start. I dont know what else to do it is getting fuel and it is getting spark. Any help and advice is appreciated
I can tell you where the connector is on a '91 Silverado
I am not having a good time with mine beyond that point. Access to the timing mark on the vibration damper is almost impossible to get at to mark the TDC point with chalk. I am going to have my wife who has smaller hands try to do that operation so I can actually time the engine.
bentwrench
August 25th, 2011 5:52 PM
