Chevrolet Malibu
2002 Chevy Malibu stereo wiring harness?!
Old May 30th, 2008, 5:13 PM
Chevyman347's Avatar
Default 2002 Chevy Malibu stereo wiring harness?!
I've looked everyone and there is no vehicle-specific wiring harness.I've tried the retail store "GM 94 - Up" and "GM '00 - Up" and what not,even went to a car audio-specific shop, and I installed all of them,Nothing!I bought a radio for my car and the mounting kit, but I can't install it without the harness!I was going to wire the radio directly to the existing wires in the factory radio's slot,but the colors are different (i.e. orange instead of red, etc.)What can I do?!
Old August 3rd, 2009, 9:36 PM
brodo's Avatar
Unhappy yep
yea same problum 2002 malibu doing a sterio for a guy and i cant find the right hook up im thinking about half a role of tape and about 3 hrs just hooking wire to wire till ya get it thats what im doing tuesday
Old August 4th, 2009, 8:45 AM
OnDaGround's Avatar
That would be because a ton of the GM cars use the exact same stereo just different looking. Except pontiac because they used monsoon at one point.
I used the 94+ harness and had no issues. You're saying you tried to install it with the 00+ harness and it didn't work?
Old August 4th, 2009, 8:47 AM
OnDaGround's Avatar
I highly recommend against it. You are cutting into your interior harness. If you mess it up and nothing works, then you're out of luck. It's a one piece interior harness. You cannot simply replace the part that you cut. The wires are not going to match up right. You may have several that are not used that should be.
Old August 4th, 2009, 12:37 PM
Filipino_redneck's Avatar
Did you try Crutchfield
Old April 4th, 2014, 10:07 PM
acevans1989's Avatar
Okay so having the same problem now i have installed 5 other aftermarket stereos in my cars and figured this to be the same but i did do this in extreme haste! my factory busted and the grinding noise it was producing WAS INSANITY!!! so here how it went...
like normal cut off the factory harness grabbed a 9v and found my speakers...
then proceeded to hook up to the car NOW... every thing i have looked at SAYS that there should be a second yellow wire to hook up the 12v accessory BUT i now find out after some research that there isn't a 12v accessory even though it says online in many place that the 02 Malibu has an 12v accessory that is yellow so.... What do I do now... do i try to repin the old harness and buy an adapter or is there a work around.... plz if you have a good answer speak to me like im dumb and plz be descriptive because my mental state with this car is wearing very thin lmao
Old June 21st, 2014, 4:47 PM
lagolfer's Avatar
Walmart has some wiring harnesses.
heybuddysweetbowtie
November 5th, 2021 5:42 PM
cheebs
May 15th, 2011 8:32 PM
razorback_ed
Colorado
February 16th, 2011 4:02 AM
ajayz2006
September 8th, 2010 6:19 PM
gazoo
August 25th, 2010 12:21 PM
Quick Reply: 2002 Chevy Malibu stereo wiring harness?!
