Driver Side Wheel is HOT!
Old June 21st, 2008, 6:38 PM
bassrat31u's Avatar
Default Driver Side Wheel is HOT!
Good Evening!
Brand new to the forum but need help with a diagnosis on my baby! I have a 2003 Chevy 1500 (5.3L)Z-71. I just replaced all the brake pads all the way around since I had to goto GA for 2 months. I got down here without any problems, but took the truck out this afternoon and smelled that hot brake smell. I got pulled over and checked the fronts which I believe are fine but when i got to the driver side rear the rim, itwas very hot to the touch. I poured a little water on the wheel and watched it sizzle right off. Before I pull the rim off I wanted to know if anyone could give me a clue what to look for....
E.
Old June 21st, 2008, 10:00 PM
Default RE: Driver Side Wheel is HOT!
Definately look for a stuck caliper pot.
Old June 22nd, 2008, 10:33 PM
wellmax's Avatar
I am old school,
does this model have disc brakes on rear?
if so then most probably a stuck or sticking caliper.
also could be a rubber brake line thathas collapsed inside hose, will allow fluid toflow to brake, but not return.
also could be a bad axle bearing
my money is on caliber as you have recently
worked on brakes, did you lube all slide shafts?
Good luck,
Old June 23rd, 2008, 5:02 AM
John Hart's Avatar
One other possibility is air in that line. Air can act like a spring and store compression in the piston. Did you bleed them when you replaced the pads?
Old June 24th, 2008, 6:16 AM
bassrat31u's Avatar
Thanks Again!
I pulled everything apart and took a look and the ponly thing I could find was the rotors had a lip on the outside edge from rust and dirt that was chewing up the brake pads. I replaced the rotors and pads, checked the calipers and everything seems to be working fine now.
Old June 28th, 2008, 9:44 AM
Sooner55's Avatar
I had the same problem with my 2000 Z71.
Turns out dirt and water got into the caliper and it would stick.
I replaced both rear calipers and no problems since.
driverstefan
May 3rd, 2019 11:09 AM
Beebe
May 3rd, 2019 7:37 AM
rjatherton
August 6th, 2012 10:17 AM
digitalgeek
September 15th, 2011 4:05 PM
rv4me2
April 11th, 2011 11:05 PM
Quick Reply: Driver Side Wheel is HOT!
