Old July 27th, 2015, 3:41 PM
Browse all: Powertrain Guides
Spark Plug Replacement... Help
Old July 8th, 2008, 11:29 PM
sgiles's Avatar
Default Spark Plug Replacement... Help
I wanted to replace the spark plugs on my 5.3L silverado (2005) - how hard is this job going to be? Have any of you had anyproblems or have any tips that might help me? should i remove the tires?
Thanks
Old July 9th, 2008, 1:01 PM
ehhget's Avatar
Default RE: Spark Plug Replacement... Help
Unless you have something I dont have it is a peice of cake- socket and a u-joint adapter was all I needed right in from the top. The wires were the toughest part to get off the plugs from all the heat. I would definately lube them up before you put them back on.
Old July 9th, 2008, 8:18 PM
wellmax's Avatar
buy all AC De;co tuneup replacement plugs,wires, etc:
use anti seize on new plugs, be sure they are have proper gap
us dielectic grease on new wires, so they seat properly onplugs.
off brand parts can send your computer into orbit, not worth the trouble.
remember: cheapest is not always the less expensive in the long run.
Old July 9th, 2008, 9:28 PM
eddie885221's Avatar
VERY easy, just make sure you use anti seize compound on the threads of the new ones
Old July 10th, 2008, 12:24 AM
sgiles's Avatar
should i get the delco wires, plugs and anti seize from the dealer or just order it from autozone
Old July 16th, 2008, 10:20 PM
jkgray80's Avatar
Already at 100K on an 05? Save your money on wires, not a common failure item on these engines. However, i would ohm them. I wouldnt replace them unless 1 is open. Open plugwires can still fire but the spark has to jump an extra gap.
Old July 21st, 2008, 4:28 PM
03blackburb's Avatar
Unless you are at 100,000 or have a problem then don't bother with plugs and wires. They are designed to go 100,000 before replacement.
I have 85,000 on my 03 suburban and have never touched the plugs or wires. Not planning to until 100,000 either.
Old July 22nd, 2008, 9:00 AM
fishin1008's Avatar
I have a 2001 1500 ext. cab and i have never changed the spark plug wires out. It has 150,000 miles. Im guessing i should have changed the wires by now?
Old July 26th, 2008, 10:06 PM
flyoil's Avatar
I was told, have not done it myself, but if you put the vehicle on jack stands and then remove the front wheels, you can remove the, I don't know what the official name is but it is the inner wheel well covering that is held by plastic type holders, you remove it and you can access the last spark plug a lot easier. Never tried it. just a suggestion.
Old July 27th, 2008, 2:42 AM
therewolf's Avatar
At 57,000 miles, the "100,000 mile Iridium" Spark plugs on my 04 Silverado were getting ready to melt right off the side of the engine.So don't always believe the factory hype.
Quick Reply: Spark Plug Replacement... Help
