2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
'06 Impala rear defogger not working
Old September 26th, 2008, 8:44 AM
drockwell's Avatar
Default '06 Impala rear defogger not working
My rear defogger quit working in my '06 Impala. The owners manual only references the rear defogger relay in the fuse box under the hood. I checked it and verified it was good. When you push the button on the console air controls the light comes on like the rear defogger should be working but nothing else happens. Are there more fuses or relays I should be looking for?
Old September 26th, 2008, 1:07 PM
Default RE: '06 Impala rear defogger not working
check to make sure the tab isn't broken off the window, then use a test light hooked up to both tabs while the defrost is on and see if it lights up.
Old September 26th, 2008, 4:48 PM
rbarrios's Avatar
sounds like someone prob wiped a little hard back there and broke a tab
Old September 28th, 2008, 11:13 AM
drockwell's Avatar
After looking at it closerit does appear that the tab has come unglued from the window.
Thanks for the suggestions.
Is there a special adhesive I need to re-glue this back to the grid????? or can I use anything like a super glue?
Old September 29th, 2008, 5:06 PM
rbarrios's Avatar
you need to make sure that the wires remain connected- even those on the glass. if theres a break in the wires- it wont work.
auto parts have kits to repair the lines.
But youll know which one doesnt work cause the rest of the glass clears up, except the non workin one-
but sounds like your trouble is right at the connector area
Old September 29th, 2008, 5:29 PM
Take it to an auto glass place and see if they will even attempt to repair it. A lot of places will not touch it because the heat fromthe soldering gun can cause the glass to shatter. And it needs to be solder to have a reliable fix
BMoTahoe
December 4th, 2012 6:01 AM
wile13
February 12th, 2012 8:28 PM
merlinroad
November 6th, 2008 6:48 PM
bobt
December 13th, 2007 6:23 PM
Quick Reply: '06 Impala rear defogger not working
