Job diagram - Changing oil pump
Old April 23rd, 2009, 1:40 PM
db 183's Avatar
Default Job diagram - Changing oil pump
Anyone have a job diagram for changing the oil pump in a 2000 Chevy Silverado 1500 4WD 5.3L V8?
Looking for an illustration.
Old April 23rd, 2009, 3:49 PM
Oil Pan Replacement
Removal Procedure
  1. Remove the oil level indicator tube.
  2. Raise the vehicle.
  3. Remove the engine oil and the engine oil filter.
  4. Remove the oil filter adapter.
  5. Remove the starter.
  6. Remove the engine mount through bolts.
  7. Remove the oil pan.
  8. Note the location of any studs to assist reassembly.
  9. Remove the engine oil pan and the oil pan gasket.
  10. Clean all the sealing surfaces.
Oil Pump, Screen, and Crankshaft Oil Deflector Replacement
Removal Procedure
  1. Remove the engine oil pan.
  2. Remove the oil pump.
  3. A loose oil pump screen or pipe assembly can result in an air leak and loss of oil pressure.
  4. If the tube is loose in the oil pump body replace the oil pump screen.
Installation Procedure
  1. Important: Install a NEW oil pump driveshaft retainer.
  2. Install the oil pump and the crankshaft oil deflector.
  3. Install the engine oil pan.
Old October 26th, 2011, 6:42 PM
solis4me's Avatar
can the oil pan in a 2004 silverado 1500 5.3L be removed and clear frame?
aboyaser
November 20th, 2012 9:04 AM
greatwhite99
October 21st, 2011 8:44 AM
skibumm
February 13th, 2009 10:44 AM
Roy
September 22nd, 2007 6:05 PM
sleet
October 11th, 2006 11:36 AM
Quick Reply: Job diagram - Changing oil pump
