S-10 & Blazer 1982-2005
Freeze Plugs
Old May 15th, 2009, 4:34 PM
mav06's Avatar
Default Freeze Plugs
I just bought a 2000 Blazer and it has a Freeze plug that is blow behind one of the motor mount. I wanted some advice on the easiest way to replace it. I don't really want to take out the engine and replace them. I didn't know if i could just jack up one side of the motor and replace it. I haven't replaced freeze plugs before. So i am looking for any advice or mistakes anyone has made in the past and learned from them
thanks a ton
Matthew
Old May 15th, 2009, 5:02 PM
Ride of the Month
May 2009
mudmaniac's Avatar
I would think that if you removed the motor mounts you should be able to jack it up slightly, I'm not sure if you would gain enough access or not.
DWB
Express & G-Series Vans
July 7th, 2015 8:52 AM
1984gmchighserria
Astro
August 10th, 2011 1:20 PM
makingaZJ
June 14th, 2011 9:18 AM
kgb98367
November 27th, 2010 1:06 PM
mean327
January 5th, 2009 12:13 PM
Quick Reply: Freeze Plugs
