Platform: A-, G-, & W-body
LOW COOLANT LIGHT - 2000 Chevrolet Lumina
Old June 3rd, 2009, 9:49 AM
sonkitty's Avatar
Default LOW COOLANT LIGHT - 2000 Chevrolet Lumina
Hi. I was told by 3 different people that I needed to have my Low Coolant sensor replaced. The light was coming on intermittently at first, then flickering, then stayed on. All levels of coolant were fine.
I had the sensor replaced and now the light just stays on constantly. Is it something with the computer? I don't know. I was also suggested to unhook the battery for a few seconds and hook it back, that that should reset things.
Could that help or what else could it be?? Help! Thanks
Old June 3rd, 2009, 9:52 AM
ROTM Coordinator
Mike Sigmond's Avatar
Can you pull the sensor out and see if its clogged or dirty, maybe a simple cleaning on the sensor might do the trick. Just trying to think of things to try without spending $$.
Old June 3rd, 2009, 10:48 AM
sonkitty's Avatar
Yes, we did already have the sensor replaced this week and it's still the same problem - light constantly on
Old June 3rd, 2009, 10:50 AM
ROTM Coordinator
Dont know how I missed that , you clearly posted it Id try the battery disconnect for 10-15 min.
Old June 3rd, 2009, 12:14 PM
sonkitty's Avatar
Default LOW COOLANT - 2000 Chevrolet Lumina
Thanks . . . I will suggest that to my husband tonite to try it. I don't believe it has tried it already.
If you think of anything else, please post! Appreciate it!!
Old June 3rd, 2009, 12:17 PM
ROTM Coordinator
I am sure some other members will chime in and have more info on your problem. At least the battery disconnect does not cost any $$ even if it does not correct the problem.
Old June 5th, 2009, 11:52 AM
budsjlm's Avatar
verry well could be a short or corosion in the wires... kind of a pain to track that stuf......
s2002h69
November 11th, 2010 5:32 PM
reelcharacter
October 2nd, 2010 7:53 PM
cbr600rrnut
May 5th, 2008 12:12 PM
christiee
February 15th, 2008 5:58 PM
cdella
November 5th, 2007 2:06 PM
Quick Reply: LOW COOLANT LIGHT - 2000 Chevrolet Lumina
