Trailer Lights
Old July 10th, 2009, 9:33 AM
weewun's Avatar
Default Trailer Lights
A 2001 Suburban with the following Symptom:
1. The Taillights on trailer do not work, the Turn Signals and Brake Lights function properly.
2. All lights on Suburban work correctly.
3. No 12vdc at the Trailer Connection or plug to the receptacle when headlights on.
4. No continuity from Brown wire at Receptacle to Ground.
All of that tells me that the Tail Light (Brown Wire) is broken/loose/diconnected somewhere in the Suburban.
My question is, does anyone know if the wiring for the Trailer Receptacle (specifically the Tail Light/ Brake Lights) go up to the Tail Light Assembly on the Sub or does it go forward to the Engine/Dash area to pick up its power. I have a feeling it goes forward to pick up its power as there is Trailer Brake Controller connections at the recepticle.
My Son-in-Law will be here tomorrow to trace and fix the problem. I will appreciate your help.
Old July 10th, 2009, 7:27 PM
The trailer light wires go to the fusebox I think.
I believe they stopped hooking the trailer lights up to the taillights in 99.
Old July 10th, 2009, 8:21 PM
old dog's Avatar
Default plug
does this have a factory plug or after market ?
Old July 15th, 2009, 9:29 AM
weewun's Avatar
It came with the Trailer Package.
Sorry about the delay but was called away this weekend and didn't get to work on it.
Old July 15th, 2009, 11:46 AM
old dog's Avatar
Default lights
you may have just a blown fuse under the hood .look in the owners manual it will tell you that there is separate fuses for the trailer tow circuit .there is a large 40 amp maxi fuse for the 12 vt lead in the plug ,and separate mini fuse for each other function probably 15-20 amp .
Old July 15th, 2009, 8:20 PM
weewun's Avatar
Thks for the input, shall check this weekend when Son-in-Law comes down.
Old July 15th, 2009, 9:44 PM
jstahoe's Avatar
I had the same exact problem a few days ago. But I finally got around to check my fuses underneath the hood and sure enough, my 15amp fuse for the trailer lamps was blown. I had pulled a buddy's trailer when it happened and discovered one of his brown wires was making contact with the trailer where it was rubbing and wore of the plastic covering.
Old July 28th, 2009, 3:40 PM
weewun's Avatar
Thks for all the input, the problem ended up being a blown fuze.
intheknow
July 24th, 2014 10:38 AM
TRUCKDIVA
July 22nd, 2013 6:48 AM
DOBERDEWD
December 11th, 2011 11:35 PM
skdevore
August 26th, 2009 10:18 PM
Quick Reply: Trailer Lights
