Rear Diff oil type.
Old July 20th, 2009, 10:09 PM
Beebe's Avatar
Default Rear Diff oil type.
I'm planning on changing the rear diff. lube on my 2000 Silverado, and my 2005 Suburban. Both have 4 wheel drive. According to the owners manual it recommends synthectic 75W-90 oil. I went to a local parts store and they did not have 75W-90. They had 75W-140, and 80W-90. I was told by the owner of the store that the Amsoil 80W-90 will work just fine. Just wanted to get some other opinions. The oil does meet the GM requirements. Thanks.
Old July 20th, 2009, 10:14 PM
suzuki-guy's Avatar
I used 80 90 but is it a possi unit? If it is you need the GM possi additive or you will get possi clutch chatter.
Old July 20th, 2009, 10:23 PM
Beebe's Avatar
I don't know. How do I find out? The label on the back of the qt says it complies fith GL-5 and GM specs.
Old July 20th, 2009, 10:36 PM
suzuki-guy's Avatar
I think if you look at your RPo codes in your glovebox there should be a G80 Which is possi and you will need the GM additive!
Old July 21st, 2009, 6:50 AM
MDTAHOE's Avatar
Jack the back of the truck up so the back wheels are off the ground. Put it in neutral spin a back wheel by hand, if the wheels go the same direction put the addative in. If one wheel goes foward and one goes backwards you do not need it.
Old July 21st, 2009, 9:51 PM
I thought the G80 was an Eaton locking diff, not a clutch type. But I don't know when they started using it.
chevy619
11
December 30th, 2011 10:57 PM
AWDINNE
December 29th, 2010 12:22 PM
jgray152
July 12th, 2010 8:22 PM
jljbtm
January 25th, 2008 10:08 AM
enovativ
April 9th, 2007 12:20 AM
Quick Reply: Rear Diff oil type.
