U-joint removal & replacement
Old July 28th, 2009, 1:47 PM
jonamond's Avatar
Default U-joint removal & replacement
Im doing a u-joint for a friend in a couple of days and need some help...
I am mechanicially inclined so I just need some info
Its a 2001 2500 sil. needs a rear u-joint, If some one could tell me what specific tools and instuctions i need, it would be greatly apprecated.
Also if there any tips or tricks that I might need to know...
Thank you
Old July 28th, 2009, 5:33 PM
old dog's Avatar
Thumbs up u-joint
no telling what tool's you have but a torch ,a press would be nice Big vise or heavy steel bench to drive against ,a bmfh a good drift punch
Old July 28th, 2009, 8:07 PM
suzuki-guy's Avatar
If it is the stock plastic injected U joints you will definatley need a torch.
Old July 28th, 2009, 9:01 PM
broknindarkagain's Avatar
regular hand tools, a big hammer, a torch, and a bit of time and patience. They don't come out easy. You will probably give up several times out of anger before you get it out. Just beat the hell out of it
Old July 28th, 2009, 9:54 PM
nauticstar87's Avatar
the 2 ways ive done it, 1st and, better way, put the u-joint in a vice with a socket against the cap, then squeeze the vice. itll pop out, a lil heat with the torch would help im sure. the other way i did it was on the side of I-10 in louisiana in my last truck, a ford by the way. was hopin to make it to h-town newho, i had a c-clamp my tailgate and a big hammer and was able to punch 'em out that way, not recomennded, the c-clamp was useless when i was done.
Old July 29th, 2009, 10:40 PM
jonamond's Avatar
Thanks for the advice, If you got more keep on coming.
Thanks!
Old March 29th, 2015, 12:57 PM
Yukon98's Avatar
Default melting plastic retainer
Will a handheld torch melt plastic retainer?
Old April 3rd, 2015, 4:59 PM
Welcome to the forum...
I just did mine and yes a hand held will work but use MAP gas as it gets lots hotter, and you will need to heat the yoke up until you see it purge some of the nylon out of the injection hole...
then press or pound out the joint
wvlewis
March 15th, 2011 8:29 PM
Dawn
November 20th, 2008 10:42 AM
kellyguinn
September 1st, 2008 1:40 PM
nativebroncofan
February 13th, 2007 3:24 PM
Quick Reply: U-joint removal & replacement
