Battery Warning Light Blinking - 02 Tahoe
Old August 12th, 2009, 6:05 PM
cmjian's Avatar
Default Battery Warning Light Blinking - 02 Tahoe
My battery warning light just started to blink on and off every few seconds. The voltage meter is also down to around 12. I had a new OEM alternator put in the vehicle about 3 months ago and all wires and connections look solid. The battery is a probably 2 1/2 years old and I'm wondering if that could be it. Any insight wold be appreciated.
Thanks.
Old August 12th, 2009, 8:59 PM
Welcome to the forum. Check the battery w/ a good DVM. Fully charged should read > 13V.
Old August 12th, 2009, 10:04 PM
MDTAHOE's Avatar
Most of the time when the battery light comes on it needs a alternator. It should actually be called a alternator light. With a car or truck running the battery actually does not do much, it is kind just a buffer for the electrical system. The alternator provides the voltage, when the battery light is on it means that voltage has gone below a specific amount so when that alternator is not charging properly the car begins to run off the battery power. Then because battery voltage has gotten to low (because alternator is not working and charging) the light comes on. You should have the battery and alternator tested. The $20 or less for the test will save a lot if you get the wrong part. Just because a alternator puts out voltage does not mean it works it must put out the correct amperage to charge the battery and run the entire electrical system. Also new or almost new does not mean good. I have seen several new alternators fail days, weeks or months after install.
Old January 19th, 2017, 10:08 AM
G Tiger's Avatar
My battery connection just wasn't tight enough it happen to me today
trryhmmnd
February 27th, 2019 5:12 PM
kymberlee
March 13th, 2011 7:08 PM
sjp240
K5 Blazer
February 23rd, 2008 8:40 PM
jffgin
February 2nd, 2008 6:45 PM
r970
June 3rd, 2007 8:16 AM
Quick Reply: Battery Warning Light Blinking - 02 Tahoe
