Anti-Knock Sensor
Old August 31st, 2009, 6:15 PM
randyrt's Avatar
Default Anti-Knock Sensor
Hi,
Can someone tell me where the anti-knock sensor is on a 2001 Chevy Silverado? Also, is there a way to test the sensor or do I just replace it?
Thank you!
Old August 31st, 2009, 7:48 PM
MDTAHOE's Avatar
5.3 liter? If so under the intake. To test you need a DVOM set on the AC voltage scale. Put the red wire on the knock sensor and the black wire on ground. Tap/ hit the engine block with a metal hammer as close to the sensor as you can. If the sensor is working it will generate AC voltage the harder the knock the higher the voltage.
Old September 1st, 2009, 9:30 AM
randyrt's Avatar
Thanks MDTahoe I'll see what I can find. randyrt
jdog
September 29th, 2021 8:47 AM
jffgin
March 10th, 2008 2:32 PM
desilverado
March 24th, 2007 4:10 AM
jamesdal7
July 18th, 2006 11:11 PM
Quick Reply: Anti-Knock Sensor
