Oil Pressure guage MAXED OUT????
Old September 13th, 2009, 7:29 PM
TXPalerider's Avatar
Default Oil Pressure guage MAXED OUT????
I have a 2003 1500HD 4X4. 6.0L engine with approx 100K miles.
A few days ago my oil pressure gauge started reading maxed out. Didn't matter whether the engine was at idle or running down the highway. As soon as I started it, the gauge pegged. Truck seemed to be running fine so I wasn't really worried about it. I was thinking its was just the gauge, or the sending unit.
Today it maxed out when I started it, but when I gave it gas, the pressure gauge would fall to zero. When I let off the gas, it would max out again. It did that for a while, then after the engine got warmed up, it just stayed maxed out. Now I don't know what to think. Engine still seems to be running fine.
Any ideas?? Suggestions?? I'm not sure what to think.
Old September 13th, 2009, 9:08 PM
Speedy650's Avatar
I'm leaning towards bad sending unit.
Old September 14th, 2009, 12:32 PM
therewolf's Avatar
And I'm wondering why the sudden change under acceleration? For some reason, when there's a lot of juice provided at the alternator, the gauge reading changes...
How's your negative battery cable? Possibly a bad firewall/engine ground strap?(The one on the engine now will fight you like a dog unless you have access to a lift. Add a negative battery cable between the block and the firewall on the passenger side, and save yourself a lot of grief.) Another possibility is the ground wire at the gauge.
Old September 14th, 2009, 12:47 PM
Sounds like the pressure sender or the ground as rivereye pointed out.
Old December 16th, 2009, 8:34 AM
Replace the sending unit and it has worked perfectly ever since.
Thanks for the input.
Old July 7th, 2010, 8:01 AM
jns.das's Avatar
Default Help?
This exact problem just happened to me. The oil pressure guage is just maxed out... How hard is it to replace the oil sending unit? I see that it is behind the intake manifold on charts. Is this a DIY type of job? I mean I have changed the brakes and ebrake on this truck butI am far from being a mechanich. Also, trying to save money during a personal financial crunch. Anyone have any insight as to how difficult this is and or a basic step by step? For instance to I have to remove fuel lines? If so I am thinking its going to a mechanic because I don't have those quick release tools.
thanks in advance.
Jay
chevy_girl_forever
13
December 31st, 2017 2:04 PM
06TEXASz71
June 22nd, 2012 5:56 PM
mjnp06
April 30th, 2010 1:10 AM
USA_CAM_AUS
Camaro
June 10th, 2008 5:10 PM
teamsasky
October 29th, 2007 1:35 PM
Quick Reply: Oil Pressure guage MAXED OUT????
