wheres is bank 2 sensor 2
Old September 23rd, 2009, 5:44 PM
tat2dup81's Avatar
Default wheres is bank 2 sensor 2
i have a 2004 silverado and my check engine light came on and got code p0156. side back 2 sensor 2 is bad. im assuming its passenger side behind cat. am i correct? also, im located in kansas city, mo, does anyone know who can rebuild the speedometer on my truck?
Old September 23rd, 2009, 6:44 PM
silverado08's Avatar
ur right on the sensor, but if ur speedo is bad its easier to just go to the junk yard and get another instrument panel cluster. Only takes bout 20 min to change out. Dash cover pops off. Then a couple screws allow cluster to be pulled out. Unplug the wiring harness from back then put the other one in.
Old September 23rd, 2009, 6:57 PM
RPegram's Avatar
A bad converter will also cause this code. Speedometer is electronic, so not much rebuilding can be done.
Old September 23rd, 2009, 7:27 PM
tat2dup81's Avatar
thanks for the help.
Old September 24th, 2009, 2:21 PM
therewolf's Avatar
Short answer:
About 700$ into the top end of your engine...
Old September 24th, 2009, 4:46 PM
tat2dup81's Avatar
$700 for what?
Old September 25th, 2009, 2:16 PM
therewolf's Avatar
Labor to rip out the intake and injection rails, gaskets, new knock sensors, dealer diagnostics charges. And reassembly.
Basically, they get you for the cost of a shortblock for useless sensors which "need replacing".
Must be our lucky day!
Old September 25th, 2009, 4:37 PM
tat2dup81's Avatar
oh ok-lol. thanks for info
TylerWalker
12
August 14th, 2022 12:22 PM
holyspatulaboy
13
October 11th, 2013 1:53 PM
ldearman
May 5th, 2011 4:08 PM
mr3staks
Astro
June 16th, 2010 8:49 PM
holyspatulaboy
February 2nd, 2009 8:47 AM
Quick Reply: wheres is bank 2 sensor 2
