96 Tahoe back door hinge pin removal???
Old November 2nd, 2009, 10:41 AM
Chevelle_malibu6980's Avatar
Default 96 Tahoe back door hinge pin removal???
Hello everyone,
I have a 96 tahoe with barn doors in the back. My left door got damaged and I want to replace it. There is a top pin and bottom pin on the door. I tried knocking them out, tried an air punch, tried heating them up.
Does any have an idea on how these pins come out??? I assume that they are pressed in.
Any information would be very helpful...
Thank You,
Ryan
Old December 16th, 2009, 2:42 PM
chevyea's Avatar
I have the same truck and the same problem so far no solution yet
Old December 21st, 2009, 8:39 AM
Default Back door hinge pin removal
I ended up cutting the pin to remove the door from the truck. Then I grinded off the head of the pin. Next I started with a small drill bit. I drilled through the head of the pin. I went through several different drill bits to slowly open the hole up. Once I just the hole as big as I could without ruinning the door hinge. I punched the rest of the pin out. It took me about an hour per pin. Not fun and don't ever want to do it again....
gojaxon
July 22nd, 2022 8:50 AM
Rupesy
June 6th, 2011 1:51 PM
peshewa
April 27th, 2011 7:39 PM
2007BURB
June 13th, 2009 12:52 AM
rstank
June 21st, 2008 4:57 PM
Quick Reply: 96 Tahoe back door hinge pin removal???
