Chevrolet Sonic
GM Platform: T200, T250, T300
Clock reset itself
Old December 2nd, 2009, 12:13 PM
sergiuhusca's Avatar
Default Clock reset itself
Hy.i'm from romania.
I have a problem with the clock.
The clock permanently reset itself, when i drive or when i start the engine.i ceck teh fuses, and the batery cable.they are ok.
You have this problem with your chevy?
Old December 8th, 2009, 12:27 PM
RaulCo's Avatar
I had this same problem when receive my Aveo LS 2008 and the clock was replaced for a new one in the agency. In case that yours is not on warranty, you can review the same clock and put a plastic between the clock boards. There is two boards that probably have contact and cause the problem.
Old December 13th, 2009, 4:56 AM
david.lee264's Avatar
It can happen. Its not a very big problem and you can solve it by yourself only.
Old December 14th, 2009, 10:52 AM
Hy boys...
I have news.I was ti the service again.
They made some soldering on the motherboard clock.
After that they tell me as everithing is fine, and the clock will be working.
Well... the clock,still reset it self.I go to the service again and they discover a diode on board clock that went randomly.They change tehe diode and everithing is ok right now.
Old February 8th, 2015, 5:29 PM
jcpcplus2's Avatar
I do not see any of the answers as to how to fix the clock of the Chevo Aveo 2009 reseting to 1 00 I re connected the battery It is tight but still the clock resets Help!
Old February 9th, 2015, 9:18 AM
sledge.impy's Avatar
Did you not read above how serguihusca fixed his problems?
<table border="0" cellpadding="0" cellspacing="6" width="100%"><tbody><tr><td nowrap="nowrap"> sergiuhusca
</td> <td width="100%"> </td> <td nowrap="nowrap" valign="top"> Join Date: Dec 2009
</td> </tr> </tbody></table>
<hr style="color: rgb(0, 0, 0); background-color: rgb(0, 0, 0);" size="1"> Hy boys...
haidangwa
March 25th, 2023 6:38 PM
DEI
October 25th, 2022 8:59 AM
dacrew4009
July 7th, 2009 6:48 PM
romanlu
January 22nd, 2008 11:29 AM
Quick Reply: Clock reset itself
