output voltage of a coil
on
Does anybody know what the output voltage of a stock 60's - 70's chevy coil would be? I'm just trying to help out a friend
Thanks
RayC
Thanks
RayC
on
Thanks Bam Bam
That's what I was thinking. I have a buddy that's wanting to use one for a powder coating power supply. He's talking about using a 24 volt power supply Thur an rheostat to provide voltage to the coil primary. In turn getting 30,000 to around 50-60,000 volts out of the secondary windings
RayC
RayC
well you can use a newer coil and get pretty close to that with 12V...
something else that may work is a neon sign transformer they put out those kind of voltages
on
Thanks
RayC
It would have to have AC connected to the coil (transformer). A car uses points or electronic circuits to accomplish this. Straight 12v dc hooked to the primary side of a coil accomplishes nothing but produces heat such as burning the coil up.
haidangwa
January 17th, 2007 9:16 PM
