Why won't engine switch to closed loop?
Old February 28th, 2010, 10:53 AM
sloppydawg123's Avatar
Default Why won't engine switch to closed loop?
It is a 97 4.3 vortec, but only runs in open loop, and runs lean at that.
What makes the engine switch to closed loop?
And shouldn't it run rich in open loop?
Old February 28th, 2010, 2:26 PM
cam3439's Avatar
I would think that it would run rich in an open loop. Have you checked your O2 sensors? Your truck should run open loop until the O2 sensors warm up and tell the computer if your truck is running too rich or too lean.
Old February 28th, 2010, 2:34 PM
the o2 sensors say it's running lean in the open loop, and it never goes to closed loop
Old February 28th, 2010, 3:21 PM
cam3439's Avatar
What I meant to say is have you changed out your O2 sensors? They might be bad. If I remember correctly, the computer runs open loop at start up and goes to close loop once the O2 sensors give a reading back to the computer. From here the O2 sensors' readings will tell the computer if you're too rich or too lean. And I don't know what to tell you on running too lean. I think that the O2 sensor is giving a false reading (on account of it being bad) and is also the reason why it's staying in an open loop. How many O2 sensors do you have?
Old February 28th, 2010, 4:12 PM
4 o2 sensors, the readings they send back to the scanner say bank 1 is lean
Old February 28th, 2010, 4:41 PM
maxxman04's Avatar
most o2 sensors are heated by an electrical current. the truck will run in open loop until the sensors reach a certain internal temp and send a signal to the computer. as long as sensors are good, the computer will switch to closed loop once it receives the signal. vacuum leaks, worn o2 sensors, bad plugs/wires/cap/rotor can cause ecm to run open loop while it searches for the proper signal. if your rig has over 100k on it and you don't know when the last time they were changed, change them.
Old February 28th, 2010, 7:04 PM
after all that i found a cut in one of the wires off the o2 sensor, fixed the wire, seems to have fixed the problems
Old February 28th, 2010, 8:49 PM
maxxman04's Avatar
that is sweet. funny how sometimes it's somethin small and simple like that. glad ya got it fixed
Old February 28th, 2010, 9:13 PM
cam3439's Avatar
nice.
xeqshnr
HHR
22
February 13th, 2015 9:18 AM
lilrafe87
January 4th, 2014 3:38 AM
Hotwires
February 14th, 2012 9:03 AM
Mike Sigmond
May 12th, 2009 8:36 AM
sawyerd
Audio/Visual Electronics
January 2nd, 2009 12:46 PM
Quick Reply: Why won't engine switch to closed loop?
