water leak into heater blower motor
Old March 1st, 2010, 9:55 PM
usmarine0905's Avatar
Default water leak into heater blower motor
Hi, my 98 C2500,5.7 Vortec extended cab has a water leak into the heater blower motor. when the truck sits and it rains, water finds it's way into the blower housing. Anyone have any idea where this might be coming from??
Thanks
<!-- / message -->
<!-- controls -->
Old March 2nd, 2010, 3:11 PM
ristpin's Avatar
Sure it's not anti-freeze? Does it have a "sweet" smell? Sounds like a leaky heater core to me. Check your radiator fluid level.
Old March 2nd, 2010, 3:19 PM
Rodehard's Avatar
if leaf debris has clogged the drain holes in your fresh air intake, it will run in that area of the cab.
Old March 2nd, 2010, 7:38 PM
MDTAHOE's Avatar
Remove the wiper arms and then the cowl panel, you will most likely find crud in there causing water to go in to the box.
Old March 2nd, 2010, 8:37 PM
@ rispin....its not antifreeze...just water. it only happen after it rains but thank you....
Old March 2nd, 2010, 8:39 PM
@ MDTAHOE.....and RODEHARD....Thank you I will check that out this weekend. Also is it difficult to replace the blower motor assy, its started sqelling very baddly??
Splathapy
January 5th, 2023 11:26 AM
scorpion48
July 20th, 2011 9:44 PM
mathblaster
November 2nd, 2009 5:33 AM
BlackhawkCrewchief
October 11th, 2009 10:26 PM
ljwnevpl
November 22nd, 2006 4:30 PM
Quick Reply: water leak into heater blower motor
