Installing autometer water temperature gauge
Old March 6th, 2010, 9:31 AM
BENI's Avatar
Default Installing autometer water temperature gauge
I recently just bought an electrical water temp gauge by auto meter. Could any one give me advice on installing an autometer water temp gauge? Just wondering if it's a diffucult job. I have a 1989 chevy k1500 with a 350 in it. Any input would be great!!!!
Old March 6th, 2010, 10:26 AM
maxxman04's Avatar
drivers side of motor, towards front is the stock temp sending unit. take this one out, replace with autometer sensor. then just run wire thru firewall somewhere, mount gauge where you want, hook up wires. done.
Old March 8th, 2010, 9:01 AM
BENI's Avatar
thanks maxxman!! I installed the water temp sensor yesterday morning and it works great!!! It took me about an hour so it wasn't so bad. I also installed a auto meter oil pressure gauge. My only concern though is it only shows 25 PSI. I know that on my old motor and stock gauge it at least showed around 45 PSI and more when I was on the highway. Is this normal? How do I go about this if it isn't?
Old March 8th, 2010, 9:23 AM
maxxman04's Avatar
25 psi at idle or while driving? the rule of thumb is 7-10 psi for every 1000 rpm's. did you coil the oil line per instructions? it could be the old setup wasn't working properly too. double check all fittings and check instructions again to see how many times you should coil the line.
Old March 9th, 2010, 9:43 AM
BENI's Avatar
Coiling the oil line?? I followed the instructions but i don't remember seeing anything about that. I have an electrical gauge if that matters. It runs 25 PSI at idle and hwy driving.
Redwire
August 21st, 2014 1:17 PM
graysilm
December 7th, 2013 9:08 PM
white bear
July 25th, 2011 5:50 AM
sbutler430
January 22nd, 2008 1:38 PM
86_S10
August 21st, 2007 2:29 PM
Quick Reply: Installing autometer water temperature gauge
