S-10 & Blazer 1982-2005
cant get my 91 s10 to start
Old March 14th, 2010, 3:00 PM
ronnie_n_tn's Avatar
Default cant get my 91 s10 to start
about 3 months ago my s10 stopped running. it will turn over but wont start. i can start it by pouring gas in the throttle body but other than that nothing ive tried works. ive replaced the fuel pump,strainer,filter,fuel pump relay,fuel pressure regulator, igition module,ignition switch,idle air module and the computer. i when the switch is on the relay dont kick on and cant figure out why. but when i bypass the relay i still dont get any gas through the injectors. can some 1 help me out? or what else it could be? thanks
Old March 14th, 2010, 5:11 PM
maxxman04's Avatar
check all the fuses. then look for bad connection to the relay. put power to the wire that feeds the actual fuel pump and see if the pump will kick on. this can help narrow it down
Old March 14th, 2010, 5:46 PM
all fuses are good, checked all conections they are good, pump will come on if power is applied to the pump
Old March 15th, 2010, 2:30 PM
Rogers mechanical repair service's Avatar
So let me get this strait. You energize the fuel pump and it still doesn't get fuel to the injectors or is it the injectors are not spraying. Take the fuel line off at the intake to see if you have fuel getting to the injectors. My 87 had a blown rubber hose on the fuel pump assymbly. Inwhich Litle to no fuel would flow through the lines.
Old March 28th, 2010, 7:23 AM
thanks to all that has replied got it running. it was a short n a power wire that went to the main computer.
but still have an issue with the check engine light flashes rapidly all the time the truck is running. any clues?
Old April 8th, 2010, 2:42 PM
97RedBull's Avatar
just reset the codes and see if it still does it and if it is still doing that then check all your connections fot the regulator pump and lines for everything.
1999tahoe
January 25th, 2010 3:49 PM
STRAYDOG
January 11th, 2008 2:51 PM
cad
March 20th, 2007 2:37 PM
jw
February 18th, 2007 1:26 AM
dannyks_tracker
November 2nd, 2006 11:25 AM
Quick Reply: cant get my 91 s10 to start
