Platform: Delta
Also Check out ChevyHHR.net
'07 HHR engine temp gauge - engine light
Old April 17th, 2010, 2:43 PM
luvmlkwag's Avatar
Default '07 HHR engine temp gauge - engine light
'07 HHR the engine temp gauge only works some of the time - when not working the heater still works but not the A/C. If the engine temp gauge is working the A/C works. The engine light stays on for no apparent reason and the left rear passenger door lock no longer works with the rest of the door locks
Old April 18th, 2010, 10:39 PM
s34n's Avatar
pull the code from the check engine light to start with. have you checked a fuse for the power locks?
Old June 5th, 2010, 11:05 AM
luvmlkwag's Avatar
It was a damaged thermostat that was causing the engine light to stay on and the engine temp gauge to not work.
The thermostat was all shot to hell, stretched out, torn and missing some pieces. After I replaced it the, temp gauge started working again and the engine light went out after I had driven about 24 miles and has not come on since.
Roslyn2005
Equinox
February 23rd, 2017 9:03 AM
Thomas1988
May 21st, 2014 9:36 AM
montana suburban
May 11th, 2010 5:19 PM
Mauler
March 2nd, 2009 6:40 PM
wrxsubaruwrx
December 3rd, 2006 12:33 PM
Quick Reply: '07 HHR engine temp gauge - engine light
