how many quarts?
Old June 19th, 2010, 10:42 AM
tedjackson7's Avatar
Default how many quarts?
I recently bought a '98 5.7 litre suburban. Ive seen many posts that have said this motor takes 5 quarts. I changed the oil today and put in 5 quarts. It measured about an inch high on the dip stick. I drained about a quart and the level is fine now according to the dip stick.
Does this sound correct? 4 quarts?
If this isnt right I am wondering if maybe I dont have a dip stick that is the correct length.
Old June 19th, 2010, 11:59 AM
gotstylez's Avatar
look in the manual..it will tell u everything
Old June 19th, 2010, 12:22 PM
the manual also says 5 quarts....i dont mind running it a quart low but i would like to know why 5 quarts is so high on the dip stick
Old June 19th, 2010, 12:33 PM
maxxman04's Avatar
did you change the filter too, or just oil?
Old June 19th, 2010, 1:00 PM
Could be that someone replaced the dipstick w/ the wrong one. Could be that there's a quart of sludge in the bottom of the pan.
Old June 19th, 2010, 1:07 PM
LARIDERS's Avatar
on my 99 5.7L I always used 5 quarts with a oil change and filter.
Old June 19th, 2010, 4:33 PM
yes, the filter was changed also
sludge could be the case, from now on i will make sure the motor is fully warmed up before changing
jmw132001
April 28th, 2022 1:42 PM
tnb43612
June 5th, 2014 10:36 AM
Wakko
April 7th, 2014 10:15 AM
Role Chapa
May 9th, 2012 9:48 AM
XM DUDE
October 30th, 2006 5:38 PM
Quick Reply: how many quarts?
