Chevrolet Malibu
2003 Malibu, No start
Old July 4th, 2010, 8:01 AM
black's Avatar
Post 2003 Malibu, No start
My car cranks and fuel pump hums, so why won't it start
Old July 8th, 2010, 9:03 PM
ShadeTreeJack's Avatar
can you have someone check for codes?
Did it just not start one morning or did it quit running while driving?
can you check for spark? one way is to use starting fluid sprayed into the intake - I remove a hose and spray it in there.
If it starts for a second or two, you have spark but the fuel is not getting from the fuel pump to the cylinders. The injectors don't operate until the PCM tells them to, The pcm looks for a signal from the crank sensor to determine when each injector should squirt.
If it doesn't start from the starting fluid, you have no spark. could be the ignition module
Old July 9th, 2010, 6:48 PM
black's Avatar
It was the crankshaft position sensor that sits behind the balancer.
Old September 14th, 2013, 5:37 PM
Maria Ranbarger's Avatar
I have a 2003 malibu an not getting power to the ignition, the fuel gauge not working, the anti theft light is not on.It just cranks over
Old September 14th, 2013, 5:40 PM
Default 2003 malibu
wont start just cranks over, no power to the ignition, the gauges not working, everthing eles works
Old September 15th, 2013, 2:34 PM
Check the fuses. look for "ECM"and / or "IGN MOD".
If it is the ECM fuse, we will need to look for what caused it to blow. Those fuses usually do not blow unless there is a short or ?? something
Also check ground wires. or continuity from the ignition module's ground wire to another ground.
pj2k3
October 6th, 2021 1:18 PM
pj2k3
August 24th, 2013 5:20 PM
skyecatcher
June 5th, 2011 11:47 PM
bracca
July 12th, 2009 6:14 PM
ed
August 28th, 2006 4:15 PM
Quick Reply: 2003 Malibu, No start
