S-10 & Blazer 1982-2005
Brake dust shield removal
Old July 11th, 2010, 2:38 AM
svebbe's Avatar
Default Brake dust shield removal
New here...with my first Chevy ever. It´s a 1999 S10 LS 4wd. I´m in the process of removing brake calipers, rotors and brake dust shields on the rear and front. All vent fine until i needed to remove brake dust shield. How do you do it? Do i need to remove the axel to do it? Seems to be alot of work just to get the brake dust shield out.
I´ve sent for a workshop manual (DVD), but i thought i post my question here while waiting for it...
Old July 11th, 2010, 3:21 PM
Bill's Dad's Avatar
I had to remove the hubs to replace my front shields...
Old July 15th, 2010, 9:35 AM
frickenbored's Avatar
yup, you gotta remove the hubs, three bolts from the backside.
Old July 15th, 2010, 11:34 AM
svebbe's Avatar
Ok, thanks both of you!
Old July 17th, 2010, 12:36 PM
svebbe's Avatar
....haven´t got the manual yet...but it looks like below. There are no more bolts to remove as i see it...when i spin the hub on each side both hubs move....do i have to yank each hub out with force to get them loose? I can´t damage anything that way? Hope you can see what i mean on the pics....
Old July 17th, 2010, 7:00 PM
Bill's Dad's Avatar
looks like the rear dust shields you were speaking of...we thought you meant the front. To remove those(rear axles) you'll need to remove the rear cover, then you'll see a 5/16 hex head/bolt on side of carrier-remove with care, it's a locking bolt that holds in the 7/8" or so pin, slide out, push axles in to gain access and to remove C-clips then you can slide axle shafts out.
Old July 18th, 2010, 3:28 AM
svebbe's Avatar
Yes...it´s the rear dustshields i´m talking about. Forgot to mention that. Sorry. When you say remove rear cover....which cover do you mean by that? What´s the name of the cover (so i can google for pics of it)?
Thanks in advance....
Old July 20th, 2010, 4:22 AM
svebbe's Avatar
Got the manual...and now i understand what you meant...
I need to remove Rear Axle Housing cover to unveal the c-clip....and after that i can remove the axel all the way out.
Old July 23rd, 2010, 1:31 PM
svebbe's Avatar
....or i could just saw them just enough to get them over the axel maybe
Old January 28th, 2011, 9:21 PM
rbrace's Avatar
i thought of sawing mine
jwiley7
Camaro
February 7th, 2014 1:06 PM
wwotr
April 21st, 2011 1:08 AM
exuL1B47
December 3rd, 2009 6:11 PM
Bizarre11
January 20th, 2008 3:42 PM
jffgin
October 11th, 2007 7:46 PM
Quick Reply: Brake dust shield removal
