Platform: Delta
Also Check out CobaltSS.net
how to replace blend door actuator?
Old July 19th, 2010, 7:23 PM
fancypantscobalt's Avatar
Default how to replace blend door actuator?
Hello my girlfriend's cobalt is making a ticking noise behind the glove box every time the car is started. Several mechanics have diagnosed this as the blend door actuator, and I've had this same problem with my Bravada, so I'd have to agree. Anyone know how to go about replacing this? The dealer wants $250 because they say the dash needs to be removed. On my bravada, you could reach up behind the glove box and get to it. I don't think that's possible with the cobalt.
Also, anyone know if anything special needs to be done after plugging it in to make it work right? Does it need to be "calibrated" or anything?
It's a 2006 LS coupe if that matters. I wish GM would have stayed away from automated climate controls...
davidbraun57 (October 21st, 2023)
Old August 6th, 2010, 12:28 PM
rkuelbs's Avatar
The blend door and the mode door are both accessible by removing the black plastic cover under the driver's side of the dashboard. Both are on the driver's side of the a/c unit.
Before replacing, if you want to be absolutely sure you're replacing the right one, turn the car on until you hear the clicking and place your finger on both servos. You'll bee the clicking inside of the one that's faulty.
Attached a pic of what you'll see if you remove that lower cover and get your head down near the brake pedal.
Old August 9th, 2010, 1:48 AM
Andrew123's Avatar
Hi fancypantscobalt,
I think it will help you.
https://chevroletforum.com/forum/silverado-fullsize-pick-ups-21/04-c%5Ck-temperature-valve-actuator-replacement-22624/
Thank you.
Old January 29th, 2015, 12:44 AM
Klitzki's Avatar
Default blowing out cold air
I have a 07 Cobalt Ls and blows out cold air when it's suppose to be hot. Any Help?
DaniGirl
July 23rd, 2015 6:14 PM
JoeCB
Uplander
26
March 11th, 2014 3:28 PM
scumpoozie
February 14th, 2013 9:25 AM
Jack
September 20th, 2009 2:33 PM
2006trailblazer
February 24th, 2009 1:58 PM
Quick Reply: how to replace blend door actuator?
