Replacing Idle Air Control Valve
Old August 7th, 2010, 6:14 PM
mgobluetex's Avatar
Default Replacing Idle Air Control Valve
I have figured out that the issue causing my 2001 Chevy Tahoe to have RPM issues when at a stop light or parked is the idle control valve. Does anyone have any idea how to replace or where to find it? All of the information that I have found online refers to ICV's that are cord driven and my Tahoe controlled by an electric throttle. Any help would be appreciated. It is hot outside and I want to get this fixed so that I can have AC when stopped. Thanks a lot for all information!!!
Old August 7th, 2010, 10:18 PM
maxxman04's Avatar
idle air control valves are all electrical, whether the throttle is cable or electric doesn't matter. iac's are mounted on the throttle body itself, usually with 2 bolts/screws, and an electrical connector. this link shows the iac for the 5.3 motor.
http://www.oreillyauto.com/site/c/de...2169&ppt=C0018
Old August 7th, 2010, 10:25 PM
mgobluetex's Avatar
I have the part but I just don't see where it goes. Is it right next to the Alternator?
Old August 7th, 2010, 10:36 PM
maxxman04's Avatar
it goes on the throttle body, which is on the top of motor where the air goes into engine. you'll have to take the air intake tube off, then look on drivers or passenger side of the throttle body (the throttle body is basically the carberator looking part)
Old October 29th, 2010, 2:51 AM
javedjee77's Avatar
Default cleveland taxi
Thanks for this
Old October 29th, 2010, 8:06 AM
also take a read of this artical and see if it might apply..
http://ww2.justanswer.com/uploads/Bl...e_cleaning.pdf
454BBC
April 30th, 2013 5:48 PM
TahoeMatt
February 28th, 2013 8:13 PM
RScottYukon
February 17th, 2013 8:18 PM
83_Caprice_Classic
September 21st, 2010 2:12 PM
Quick Reply: Replacing Idle Air Control Valve
