silverado dies out while driving???
Old November 29th, 2010, 2:37 AM
aukai22's Avatar
Default silverado dies out while driving???
i have an 06 chevy silverado and while driving my truck just shut off and then it takes about 2 to 3 cranks for it to start back up. then it will run okay for 2 days then do the same thing.. please help.
Old November 29th, 2010, 5:40 PM
OLD WRENCH's Avatar
Something like this can be a bear to find. I would start with the fuel filt if it hasnt been changed in a while. Pull it off and try to blow thru it there should be very little resistance.
Old November 29th, 2010, 10:59 PM
aukai22's Avatar
thanks for the advice already changed the fuel filter. any other suggestions.
Old November 30th, 2010, 12:29 AM
OLD WRENCH's Avatar
Then I would check the fuel pressure.
Old November 30th, 2010, 8:10 AM
jvc350's Avatar
Check the fuel canister. This is in the back by the fuel tank. It grabs the overflow.
I just had to replace one on a 08. It will cause problems with fuel flow and it musts be changed.
Old November 30th, 2010, 1:02 PM
silverado13's Avatar
could be your fuel pump going out
Old December 1st, 2010, 11:27 AM
aukai22's Avatar
thanks for all the advice but i already change my fuel pump and the canister and the fuel pressure is fine. any other suggestions?
Old December 2nd, 2010, 7:33 AM
jvc350's Avatar
How about electrical? Or Maybe there is a problem with the mapping (Maybe Timing is off a bit)? Have you checked any codes?
Old December 2nd, 2010, 9:17 AM
inspect all your plug wires and spark plugs, and yeah defidently check for codes
Old December 3rd, 2010, 10:31 AM
aukai22's Avatar
checked the codes and all it is, is a bad cat converter but i doubt that would cause a stall.
Quick Reply: silverado dies out while driving???
