Manually shift electric transfer case ???
Old December 26th, 2010, 7:30 AM
dleesco's Avatar
Default Manually shift electric transfer case ???
2001 Silverado 2500 Hd
Hey Is it possible to bypass the actuator on a transfer case and engage 4x4 manually ? I believe my rear actuator is smoked cause when i push the 4 hi button the light flashes 5 times but never engages i hear the electric motor but just goes back to 2 hi . Makes me think the axle actuator is ok but do they work together electricly? If i can shift the transfer case will the axle one engage also ? Is there a way to bypass both ? Its Sunday with a big snow storm coming not sure what i can find for parts ?
Thanks
Old December 27th, 2010, 9:46 AM
OLD WRENCH's Avatar
Not an expert on this but if you have a defective part I doubt if you can by pass it. There are at least two companys that make a kit that converts them to manual. They are quite involved to install. A Google search should find them.
Old December 29th, 2010, 12:18 PM
silverado13's Avatar
agreed, i wouldnt bypass it because i did that with my 97 and then i couldnt get it out of 4low and that sucked, just go to the junk yard and replace things
c.parry95
September 17th, 2014 6:09 PM
deh1
August 28th, 2011 6:47 PM
AustinPowers
August 16th, 2010 2:08 AM
pro_51492
January 26th, 2010 5:01 PM
paulj84003
December 23rd, 2008 11:46 AM
Quick Reply: Manually shift electric transfer case ???
