Looking to get more power out of my 350
Old January 3rd, 2011, 8:06 PM
Like_A_Rock's Avatar
Default Looking to get more power out of my 350
I have a stock 350 with TBI. My only preformance upgrades are a K&N filter, headers, straight pipes and glasspacks. Mobil 1 oil with wix filter. Its got decent power being stock, but I want more. Is there a way I can get more power with out spending a whole lot. No like 2 day projects or anything but are there small things I can do to make it better?
Thanks,
Aaron
Old January 3rd, 2011, 9:47 PM
RacerX's Avatar
rebuild the motor so you can start from scratch with maximum performance in mind. Otherwise, forget it. 250K miles? Why bother? Open that sucker up and then start from anew with a plan on making a horsepower player.
Old January 4th, 2011, 7:02 PM
because the engine was replaced at 213k
Old January 10th, 2011, 9:33 AM
Starboy's Avatar
You're running glasspack mufflers? I've learned that straight-thru mufflers are actually more restrictive, not less. They don't allow efficient exhaust flow, I guess. I run the Turbo mufflers, 2 1/4" in and out, 2 1/4" exhaust pipes on long tube headers with a crossover balance pipe, and I get full flow all the way up through my RPM range. I have not run Flowmasters, kind of a budget thing, but they get good reports from owners. If you're running glasspacks, you might ask around about their flow characteristics vs: turbo or Flowmaster? It worked for me, no doubt. Dramatic improvement.
Old January 13th, 2011, 12:20 PM
lswhaaat's Avatar
You can install roller tip rockers like the ones below for around $250 and you will gain about 15-30 HP out of your engine. usually this is a 1 day job, and well worth it!
http://www.prwonlinestore.com/blumax...kerarms16.aspx
Old January 13th, 2011, 1:19 PM
I'll have to look into that after I fix my trans, Thanks for the info!
1994Suburban2500
June 14th, 2015 11:45 PM
67 Impala SS
Engine Building & Overhauling
October 20th, 2013 2:05 PM
downen
May 17th, 2012 6:44 PM
Belvy83
October 8th, 2007 5:12 PM
Belvy83
September 20th, 2007 8:31 PM
Quick Reply: Looking to get more power out of my 350
