Chevrolet Malibu
Rear end noise from back end. maybe suspension?
Old March 15th, 2011, 4:01 PM
TASpinney9110's Avatar
Exclamation Rear end noise from back end. maybe suspension?
(2004 Chevy Malibu Maxx) Driving down the road the car is quiet as always, the second i hit a bump it makes a rattling sound somewhere in the back end. I narrowed it down to the left side and put it in the air. I thought it might be the exhaust rubbing or hitting but it seems to be coming from the suspension somewhere. Can someone help me figure out whats wrong!!!
Last edited by TASpinney9110; March 15th, 2011 at 4:01 PM. Reason: forgot somthing
Old March 15th, 2011, 5:54 PM
EinST's Avatar
It could be anything in that mess of links and bushings. Does yours have springs/shocks or struts? If shocks, check the upper shock mounting (should be torqued to 66 lb ft if single bolt, 18 lb ft if two nuts). If struts, it gets easier, see if you can push/pull the top of the tire in/out with the vehicle on the ground. If you can, the upper strut mount is most likely loose. It's something that's not really apparent with the shock/strut at full extension under spring tension.
Equinoxowner
Equinox
73
May 3rd, 2022 10:56 AM
Simon-Pierre Lacasse
Express & G-Series Vans
March 8th, 2014 7:18 PM
ag2
February 14th, 2013 10:30 AM
z71black2012
Colorado
October 16th, 2012 2:07 PM
Mike Sigmond
23
September 22nd, 2009 5:18 PM
Quick Reply: Rear end noise from back end. maybe suspension?
