99 suburban miss fire
Old March 18th, 2011, 7:56 AM
ekamm's Avatar
Default 99 suburban miss fire
I am a first time poster here and have an issue with my 1999 suburban, 4wd, 5.7L, 153K. The engine light came on the other day after it had been idling a little rough. I went have the code read and the guy said that it was a miss fire on #6 cylinder. Are there any obvious things to check or look for? Is there a common issue that I should check first?
Old March 18th, 2011, 5:16 PM
EinST's Avatar
Do a web search for trouble code P0306? It basically means cylinder #6 didn't contribute enough to the crankshaft output. Check for the usual suspects such as ignition and fuel injection components, and compression on that cylinder.
Old March 19th, 2011, 5:44 AM
loneViper's Avatar
I know this is gonna sound strange but my 99 Suburban had the exact thing and it turned out to be a leaking intake manifold gasket. apparently the Dex cool antifreeze ate the gaskets out. The problem was fixed with new gaskets and green antifreeze.
Old March 19th, 2011, 7:30 AM
shamrock246's Avatar
got that problem after changing/upgrading the intake manifold gaskets it turnout being a stuck poppet valve in the fuel injection spider i did the spider upgrade and cleaned the mass airflow sensor and it runs great now the fuel injection spider upgrade is worth every penny,check for spark and compression
Sean
1997 burb
Old March 20th, 2011, 11:39 AM
ekamm's Avatar
I have been losing coolant as well but no leak visible. So I guess that it is possible but how to tell for sure ?
Old March 20th, 2011, 8:36 PM
Check around the water pump weep hole. If it's not coming out there, then it is either going into the crankcase or combustion chamber. Neither are good options.
Old March 20th, 2011, 9:24 PM
legolas894's Avatar
I'm going down this road too. Can I ask you what it cost for that work? I was told $800. They do a couple of these every month.
Old March 20th, 2011, 9:28 PM
If the antifreeze is getting in the oil for very long, then there'll be more to fix than just the gaskets.
Old March 21st, 2011, 5:16 AM
loneViper's Avatar
It's been a while since I had ours done but I do think it was in that $600 range. Course the Dex cool had to be flushed and green anti freeze installed. There is also a significant amount of labor. It deffinately cured the problem though. It would only be a matter of time before it got into the oil.
problemEquinox
Equinox
February 3rd, 2014 10:43 AM
healyk7190
January 29th, 2013 9:53 PM
nkh34
September 11th, 2012 7:00 PM
80impala
June 25th, 2012 8:00 AM
dannymiami
January 20th, 2011 9:25 PM
Quick Reply: 99 suburban miss fire
