chirping noise coming from 07 tahoe
Old April 12th, 2011, 11:11 AM
nytahoecop07's Avatar
Default chirping noise coming from 07 tahoe
i have a "chirping" noise that sounds like its coming from the front right tire area when i drive. it gets faster as i accelerate but can only be heard at low speeds. my mechanic took off the wheels and said that the brakes and wheel bearing are all in good condition...any ideas what this could be?
Old April 12th, 2011, 1:30 PM
hicksvilleshick's Avatar
ok, so it's only when you are moving?
does it go away when you step on the brakes?
:chug:
Old April 12th, 2011, 2:05 PM
yea, its stops when i step on the brakes
Old April 12th, 2011, 6:24 PM
I'm gonna go with likely the brakes then. I'd replace the pads. unless they are like brand new... might also have the rotors checked see if they need turned...
how long/many miles have the current pads been on?
:chug:
Old April 12th, 2011, 8:09 PM
brakes have less than 5k on them...wondering if the rotors were not cut last time brakes were changed and if so could that make the noise
Old April 14th, 2011, 3:49 PM
man hard call. the only thing I can think of is if the rotors were warped and wore down that area of the pad and the scraper is getting into part of the rotor... I guess you could pull the pads and try to eyeball them to see, but if you can't tell there the only way would be to pull the rotors and have them mic'd, it'd be the only way to know "for sure" it ain't the brakes...
do you feel a pulsing in the brake pedal under braking (esp hard braking)?
:chug:
Old April 15th, 2011, 10:52 AM
Official GM Rep
nytahoecop07, have you ever gotten an opinion from your dealership to see if they might have a bit more insight into this issue or are you looking to fix this on your own at this point? Thank you.
Jeff Morris, Chevrolet Customer Service
Old April 16th, 2011, 12:32 PM
havent brought it in yet because ive been busy doing wedding planning and other such "exciting" thing haha...and the dealer i bought it from is listed as the place that did the last brake replacement so theyre low on my trush meter right now...going to have to bring it to a different dealer to check it...since its got 11 months left on the bumper to bumper certified warrany im hoping that brake installation mess ups by a dealership is covered
Old May 31st, 2021, 1:42 PM
dtmeeks's Avatar
check your sway bar links, really cheap fix, I had a 09 Silverado and when they went bad they’d sound like spare change in your pocket
GreaseMonkey4x4
June 25th, 2012 10:01 AM
Jenkins
November 3rd, 2011 1:39 PM
valvano
June 29th, 2011 12:34 PM
Kevinh111
October 13th, 2009 8:54 PM
dakine503
October 2nd, 2007 8:24 PM
Quick Reply: chirping noise coming from 07 tahoe
