Steering column wiring
Old April 25th, 2011, 2:23 PM
cyras21's Avatar
Default Steering column wiring
Anyone have any diagrams of this? What I'm wanting to do is find the wire that cuts the fog lights off when you turn the brights on.
Old April 25th, 2011, 2:52 PM
Guessing you are referring to an NBS 07 and up?
I believe its BCM controlled... but I am sure its doable... I'd like to try wiring mine up like I had my 97 so that when I lit up the brights my low beams stayed on as well...
Old April 25th, 2011, 5:26 PM
Jeff: The NBS brights do keep the lo-beams on.
cyras21: Not sure why one would want to do that as the brights actually reduce visibility in the fog.
Old April 25th, 2011, 5:46 PM
cyras21's Avatar
No, I want the fogs to stay on when I flip the brights.
Low beams only
Low beams and Fogs
Low beams, Fogs, and Brights
Old April 25th, 2011, 6:39 PM
Really, I didn't know that. will have to check it out this eveing
maybe that is why the fogs go off when you go to high beams for the current draw....
Old April 25th, 2011, 8:20 PM
Why? It's counter-intuitive.
White79
August 9th, 2011 11:11 PM
Dark Volker
September 10th, 2009 3:03 PM
patioman
May 11th, 2009 9:38 AM
taylorisafop
December 19th, 2008 4:57 PM
jeffwsi
K5 Blazer
August 12th, 2007 7:30 PM
Quick Reply: Steering column wiring
