Brakes not releasing
I have new rotors, calipers, pads, and bearings.
When I apply pressure to the brakes they will not release. If I open the bleeder screw they release. As far as I can tell its only the front. I did already bleed the whole system as well.
The brake system is all the same as a chey 1 ton of the same or similar year. It has the bendix type calipers w/ hydro-boost.
I have never worked on a hydro-boost so there may be something I am missing, or its the master cylinder. Just wanted a second opinion before replacing it.
it is a 78 g30 motorhome dually
It did seem like it was taking excessive pressure to stop abruptly.
on
84 305 wont run well with coolant sensor
I am new and cant figure out how to post!84 Impala 305 4 barrel 70,000 ACTUAL mi.wont run well with coolant sensor hook up dead miss and loss of power, unhooked runs much better at about 90 %,,,,if you can start me in the right direction i would appreciate it.Will not run good with replacement of TX1,2 wire sensor.I wonder if i found wire for new TX1 temp. sensor would it fix it,ALSO IS THIS POSTED IN THE RIGHT PLACE
Mille Racer 69
December 8th, 2010 8:26 PM
coppola7
November 22nd, 2010 11:39 AM
