2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2004 Impala Blower Motor Issue
Old July 6th, 2011, 9:07 AM
SterlingB's Avatar
Default 2004 Impala Blower Motor Issue
I have a problem that has me stumped. Several months ago the blower motor in my car became stuck on high. It stays on high no matter what setting the switch is in and also stays on even if the key is no longer in the ignition. I was told it was probably the blower control module. I replaced that along with the blower motor itself. The problem is still occuring. Can anybody help me with this?
Old July 6th, 2011, 12:12 PM
EinST's Avatar
Welcome to the forum. I guess that leaves the HVAC control module itself. Are you pulling the 30A HVAC blower fuse to stop the motor? Instead, if you pull the 10A A/C Cruise fuse from the left I/P fuse block and 10A DIC/RKE fuse from the right I/P fuse block, you'll completely pull the power from the HVAC control module. If that stops the motor, the fault will be within the HVAC control module.
Old July 16th, 2011, 11:31 AM
Chevygurl87's Avatar
I'm having the same issue but my car is a 2005. We tried what you said to do and the blower motor is staying on. What else could it be?
Old July 16th, 2011, 2:09 PM
kevinkpk's Avatar
I'd suggest pull fuses associted with the a/c, or heater controls, but not the fuse to the motor itself. That should help isolate what the cause is keeping the motor on.
Old July 16th, 2011, 3:22 PM
EinST's Avatar
The blower motor control processor module is powered by the 30A HVAC blower fuse (hot at all times). It then runs the blower motor according to the speed control signal from the HVAC control module. The HVAC control module (control head, if you will) is powered by the 10A A/C Cruise fuse (hot with key on) and 10A DIC/RKE fuse (hot at all times). Thus, if the blower motor continues to run with the HVAC control module powered down (both said fuses removed), the blower motor control processor module is probably at fault.
Pat the Dad
August 22nd, 2015 2:26 PM
scnolan68
July 10th, 2014 10:00 PM
cableguy83
July 15th, 2012 2:37 PM
The Alpha Dawg
January 13th, 2009 7:03 PM
Quick Reply: 2004 Impala Blower Motor Issue
