S-10 & Blazer 1982-2005
A/C Compressor won't turn on
Old July 13th, 2011, 3:25 PM
remington22girl's Avatar
Question A/C Compressor won't turn on
Took it to a mechanic and he said the switch is bad, is there any way to bypass this switch and just have it kick on when I turn the AC on? Also, previous owner cut off vents how do I get these to turn back on/switch on
Old July 17th, 2011, 5:54 PM
mavmannate's Avatar
That is a very time consuming project right there depending on how many pcs they ripped out. An option would be to tear out the cover for the heater core and put some 12volt fans down there. You will have much more air flow, but you will loose leg room for the passenger.
Old July 19th, 2011, 11:11 PM
Well, it is a blazer and the heater core is on the middle hump, plus it leaks and I have to replace it anyways, I will try this and keep you updated. Thanks!
Old July 23rd, 2011, 1:04 AM
dcw
dcw's Avatar
you can buy a switch at auto zone it only cost about 8 or 12 bucks it is located on the acumalter it has a wire coming wires comin from it going to the compreser as for your other problem i woud go to a salvage and see if i can find those parts
scumpoozie
August 15th, 2023 9:12 AM
ZChevyAK
November 13th, 2015 6:45 PM
G T Igofast
September 3rd, 2013 3:46 PM
Steeltown
June 22nd, 2011 8:24 PM
silverado01ls
January 4th, 2007 6:36 PM
Quick Reply: A/C Compressor won't turn on
